Hi All,
I'm in new CNC project. This time with steel base ( X and Y axis from steel, Z axis from aluminum)
Base will be welded from 80 x 80 x 5 mm (3.15" x 3.15" x 0.2") tubes.
Y axis (1400mm or 55") wil be from 140 x 80 x 5mm (5,5" x 3,15" x 0,2").
Overall dimensions 1600 x 1400 x 300 mm (63" x 55" x 15").
For X and Y axis travel I plan to use Ahrens (aka. cncrouterparts) R&P system.
Hiwin HGR20 Profile Rail will be used for linear gear for all axis.
But, I was wondering what stepers I need to use nema 23 (3Nm) or nema 34 (8.6 Nm). I cant imagine what force will be needed for steel frame.
From that choice depends other electronics choose.
Here few early design renders:
Thanks for any advice !
