586,795 active members*
3,020 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma Osp U10M alarm 995
Results 1 to 7 of 7
    Apr 2011
    112
    Hello guys i have change the ucmb reload the parameters And Im getting this alarm p 955 . Machine serial number . It must be chamge Somehow?
    Allex
    Aug 2011
    420
    You must reinstall software before restore parameter
    "Imagination is more important than knowledge."
    Apr 2011
    112
    Quote Originally Posted by kurmay View Post
    Î have instaled from extended instal 1/6 to 6/6 And reload system beckup Disk . Olso If i want to do a FR instal it gives a error. Înhame notice my dram sdram And flash from new ucmb îs larger in MB the original one
    Aug 2011
    420
    Quote Originally Posted by aventtini888 View Post
    Check serial numbers is same floppies and machines.
    And did you initialize memory disk?
    Apr 2011
    112
    Re: Okuma Osp U10M alarm 995
    I have done the initialize memory disk, i getting this 955
    0955 Spec. code: data file
    [Code] ABCCCCCC
    A:
    1-> NC specification code file (FR0A
    2-> EC specification code file (FR0A
    3-> NC specification code file for PLC created by MTB (FR0G
    4-> NC specification code file for PLC created by MTB (MD0G
    B:
    1-> No file is found.
    SECTION 3 ALARM P
    4187-E P-74-R2
    2-> File attribute and sector size do not conform to ’SPC1’.
    3-> Mismatch of the machine number
    3-> Mismatch of the machine name
    4-> Mismatch of the specification code data
    6= -
    7= Mismatch of the specification code data (such as machine number, machine name, and coded data)
    except for the data stored in the specification code change file
    8= The file is not OSP-formatted.
    9= File open error
    A= File read error
    CCCCCC: 000000 ... BÅÇ5
    XXYYZZ ... B=5
    XX: Byte position of the mismatched specification code
    YY: Mismatched specification code data
    ZZ: Specification code data (before change
    An and if i make this FR instal im getting this 152
    152 Memory disk ROM write
    An error occurred in data writing onto the memory disk (FR).
    [Character-string]
    Start of writingThe transition from read-only mode to program mode does not take place.
    End of writing The transition from program mode to read-only mode does not take place.
    Verify Verification proved that the data written onto the memory disk (FR) did not match the original data.
    Element deleteElement in the memory disk cannot be deleted.
    Running task During task running, writing was attempted onto the memory disk (FR).
    [Code]
    1-> An error occurred in the memory board No. 1.
    2-> An error occurred in the memory board No. 2.
    XXXXXXXX->Address near the error location
    [Probable Faulty Locations]
    1) Defective memory disk (FR)
    2) Defective control software (in the case of task running)
    [Measures to Take]
    Change the memory board or flash memory card causing the error. * Correct the control software (in the case of
    task running).
    It can be a size problem ?? i had a 8m flash memory and now its a 16mb
    Aug 2011
    420
    initializing MD and installing software is not the same thing.
    Apr 2011
    112
    In the instal meniu , We have instal FR-instal MD install And maintance . Inside maintance There îs extedned instal And initializing Memory disk. First you do md then extended instal
  1. Okuma U10m :getting program to run
    By kirby in forum Okuma
    Last Post: 01-11-2018, 02:12 PM
  2. Okuma OSP U100M / U10M
    By bajivan in forum Okuma
    Last Post: 11-07-2014, 02:20 PM
  3. Replies: 4
    Last Post: 02-18-2014, 12:10 AM
  4. Replies: 1
    Last Post: 01-30-2014, 09:13 PM
  5. Okuma osp-u10m
    By babanh in forum DNC Problems and Solutions
    Last Post: 01-18-2012, 02:29 PM
