Hello everyone,
welcome to yet another Momus build thread, this is my 1st though.
This one is going to be a little bit crazy and perhaps overly ambitious, but please enjoy... :-)
First of all: *** Thank you, Bob! ***
Your Momus is great platform that is just awesome in may ways, not just in functional aspects but also economical to build.
What I am trying to do with this machine is to come up with a specialized Momus that make it into a tool for tasks that a common woodworker runs into all the time, and perhaps some more!
One of these things is end grain routing, to easily make CNC joinery elements, such as dove tails and finger joints, etc.
If you're not sure what that entails, this is where the workpiece is sitting vertically inside the machine, instead of laying it flat onto the spoilboard.
This requires an opening in bottom of the machine bed to insert the workpiece from underneath the machine and clamp it there securely.
I also want to utilize the machine to do bigger carving jobs, such as making signs, etc., so it had to become much longer than the original.
Currently, I'm still going for the belt driven approach on the x-axis, to see how that works out in terms of repeatability with a Kevlar belt, but I've already looked at other options.
Perhaps a Bell-Everman drive or a spindle, this will be a retrofit later on.
Another thing I wanted to be possible within the cutting envelope was a way to do full "in the round" carvings. Think pens and garden knomes ;-)
The idea here is to add a 4th axis in the shape of a trunion type arrangement.
I'm not there yet in the design, but theoretically that could be a stepper driven mini lathe-chuck, on a removable base that fits into the bed with a corresponding tailstock on the other end to hold the rotating workpiece securely from both ends.
These are just crazy visions so far, even an automatic tool changer system using a standard router is something I'm seriously thinking about too.
For the above, I needed a little more Z-axis travel which caused the whole machine to become higher.
Being a somewhat seasoned woodworker, dust collection is a really big issue for me that I intend to incorporate into the machine too.
In a nutshell, these are the major dimensional mods that are present in my version of the Momus:
- Raised the machine bed by 3.5", which caused the z-axis to be longer, allowing for more travel.
- Increased the length of the bed to about 6 feet.
Other mechanical improvements:
- Aluminum spacers inside the gantry tube as created by Charlie (cwelkie), thank you!!! :-)
- Z-Axis spacer block replacement by solid adapter plate with spacer bars, also originally designed by Charlie
- Z-Axis thrust bearing implementation as suggested by Bob.
- Different cable management system using energy track chains (still finalizing that part)
Of course, all that called for a totally different cover design.
For the actual build, here is where I'm at right now:
Been at it a few weeks already, I started with building up a model of the entire machine in Sketchup using Bob's plans and made my modifications.
All the metal work on the gantry and the carriage is done, that was quite a ride. I will post some pictures on that journey later. :-)
The rails are next on the metal work menu, but I'm still torn between precision ground or cold rolled rails.
I still haven't picked a supplier for the precision ground rails, most of what you can find online is O1 tool steel and that stuff is pretty darn HARD to work with.
I'm kind of freaked out thinking about the number of holes that need to be drilled and tapped into O1 hardened steel, so go figure...
Right now, I just started the woodworking part of it and am working on the supporting table, yay! :-)
About this table:
Having watched many of the existin Momus videos, I noticed something that bothered me a whole lot:
Some of the machines that have been built are shaking violently as the gantry/carriage moves around at higher speeds.
Trying to solve this problem to start with, lead me to design a super ridgid workbench style base table that the machine will rest on.
It's a tank, I tried to make it as heavy/sturdy as I could...
Being this heavy, I still wanted to be able to move it around easily in the shop if needed, so the table rests on four retracable casters from Rockler.
Also from Rockler, each leg has a furniture leveler that allows the machine to be stable on the floor while in use.
I tried to keep the table at a width that would allow it to go through a standard American door (~30 inches) if needed.
The Momus itself will not fit through a door at that orientation (32.5" wide), I figured I could strip the whole thing down and get the base through seperately by flipping it up if needed.
Lol, I almost think the decision by Bob to make the depth of the original Momus 27.5" had something to do with the witdh of American doors, because that's just about the width of getting something through a door easily without taking the door off the hinges... Did it?
I've talked to Bob while modeling the inital version of the machine and got a number of good pointers from him on how to improve it and what he was thinking about for V3.
@Bob: Very special thanks on the new z-axis thrust bearing design you shared. That seems to work great and attached are pictures on what that came out to with the part numbers of the INA bearings and washers I ended up using.
Here are some pictures of what went on so far, enjoy... :-)
Mac
2013-05-02 19_07_41-MomusX2.skp - SketchUp by mkloberg, on Flickr
0005-Base by mkloberg, on Flickr
0006-Closeup by mkloberg, on Flickr
0003-InitialRender by mkloberg, on Flickr
2013-03-17 22_25_44-MomusX2.skp - SketchUp by mkloberg, on Flickr
WP_20130306_001 by mkloberg, on Flickr
WP_20130412_007 by mkloberg, on Flickr
WP_20130412_015 by mkloberg, on Flickr
WP_20130418_002 by mkloberg, on Flickr
WP_20130418_004 by mkloberg, on Flickr
WP_20130418_007 by mkloberg, on Flickr
WP_20130429_009 by mkloberg, on Flickr
