588,152 active members*
4,501 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > How will I be limited by a slow spindle speed?
    Jul 2017
    5
    I recently completed a CNC conversion of a Shopfox M1111 Benchtop Mill (basically an SX3). The maximum spindle RPM is 1800.
    I've been researching speeds and feeds and trying to get a feel for it on my machine.
    My only intention is to cut aluminum, I don't have much desire to cut steel with this machine. For aluminum, many people seem to be using RPM's in the 3000-6000 range.
    Can I achieve similar results using a proportionally slower feed rate at a lower RPM? I'm not typically in a hurry to get pieces finished, but if I'm going to be constantly fighting other issues (surface finish, worn tools, etc) with 1800rpm I'll do something to address it.
    Lastly, I think I should tend to use larger diameter endmills at lower RPM's, does this make sense? Right now I'm primarily using a 3/8" carbide high helix endmill.
    Dec 2013
    5722
    Re: How will I be limited by a slow spindle speed?
    I would stick with the 3/8 endmill. Yes, just decrease the feed rate to keep the chip load in a reasonable range.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2018
    92
    My experience has been that you need both RPM and rigidity to be successful. People often under-size both when dealing with cutting aluminum. It might be soft, but you still need to provide a certain number of RPM to keep that head from moving around. I feel like the lower RPM causes the head to oscillate more. I know when I had my bridgeport, I could mow through material at 1800 RPM and it would just go through. Currently, my PM25 seems to be a lot more affected by exactly the same settings. At a higher RPM and more feed, it does fine.
  1. VM17 Spindle speed limited
    By Ozfab in forum Milltronics
    Last Post: 03-04-2020, 07:12 AM
  2. Maho speed second gear limited 800rpm
    By VPS in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 05-09-2019, 12:05 PM
  3. MV Junior Spindle Speed way too Slow
    By nordlichtFanuc in forum Mori Seiki Mills
    Last Post: 12-28-2018, 10:03 AM
  4. Is cutting speed limited to Z-axis speed
    By Beefy in forum Waterjet General Topics
    Last Post: 02-13-2010, 11:06 PM
  5. Slow Spindle Speed
    By mikemill in forum Syil Products
    Last Post: 01-20-2010, 01:48 PM
