Hello,
This is my first post on this forum and I’m not sure if this is the correct section to post but it seem to fit.
I would like to know about DC motors. I need to find a motor for an application I’m building. I need a DC motor to run on as little volts as possible, the diameter should be less than 1 inch, the motor should have an RPM at about 120 240 RPM.
I found all these requirements in some motors the only thing I don’t understand it the Torque or oz-in torque. Can someone explain oz-in torque and how this value would be would be used to determine a motor?
thejoe
