588,603 active members*
10,283 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > HAAS LATHE Graphics Simulation MODE
    Jul 2003
    212
    Greetings group.
    When I goto to "Graphics Simulation" mode and I want to zoom in with F2, I get the error message, "NO ZOOM IN 3D". What the? I've used this feature before and it worked fine. What am I doing wrong?
    JD
    927
    Dean,
    Setting #3 in the setting pages, is "3D graphics" on or off..need to change it to Off..as far as I know it will not zoom in 3d...hence the error message..
    HTH
    Jul 2003
    212
    WMS,
    That worked! I don't know how that setting got tweaked, I must have misfired while crusing around looking for a solution.
    Thank you!
    JD
    Nov 2007
    361
    you have to go to the setting that says 3d graphic turn this function off or on one or the other then it will work . you must of gave it the code to turn this off
    Nov 2005
    196
    Looks like that was resolved almost 3 years ago.
  1. Haas Tl-1 Toolroom Lathe
    By DEAN in forum Haas Lathes
    Last Post: 10-11-2012, 10:25 PM
  2. Haas Lathe Reccomendations
    By imwllc in forum Haas Mills
    Last Post: 04-05-2012, 06:21 PM
  3. Replies: 6
    Last Post: 07-25-2005, 06:00 AM
  4. OneCNC XR Series Lathe CAD/CAM Released:
    By OneCNC in forum News Announcements
    Last Post: 03-07-2005, 11:20 PM
  5. HAAS mini lathe
    By marto74 in forum Haas Lathes
    Last Post: 01-15-2004, 06:55 PM
