586,104 active members*
3,226 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > need program for okuma lb-15II. osp7000L.
Results 1 to 13 of 13
    Jun 2009
    4
    hello =)
    i have for a while been out looking for a milling program, that uses the c-axis as a Y-axis, i have a okuma lb-15II whit an OSP7000L controle panel.
    Do any one know where 2 find that ?
    Alexz
    Jan 2008
    575
    Quote Originally Posted by DK-Alexz View Post
    Impossible, that is why there is a difference between C and Y.
    Maybe be more specific in what you are trying to accomplish.
    The beaten path, is exclusively for beaten men.
    Jun 2009
    4
    hmm its because i shall make some 45angle gear on the okuma. I have made a program that are running fine but the problem are that the gear are missing the 7.2 curve on each tooth.
    So i was thinking that there must be a simular program as igf just on the computer.
    Mar 2009
    1982
    There is "IGF advanced" PC version.
    Still don't understand the way C axis can replace Y axis when cutting 45° gear. It's possible using end mill, simple 3 axis movement if machine specification allows 3 axis cutting. It's helical cutting, optional for simple Okuma M lathe
    Feb 2006
    992
    post print/ pix of the part you talking about.
    The best way to learn is trial error.
    Jun 2008
    372
    Are you after some sample code?
    NOEX VTLIN[1]=36 VTLFN[1]=1 VTLD[1]=20 VTLL[1]=50
    NOEX VWKR=9999.999 VCHKL=0 VCHKD=0 VCHKX=100 VCHKZ=-100
    DEF WORK
    PT LF,LC,[-100,0],[100,100],[100,0]
    END
    DEF WORKF
    PF 0,[0,0],100,D
    END
    CLEAR
    DRAW
    N0001 G00 X300 Z300
    N0002 G50 S3800
    NAT01
    N0100 M110
    N0101 G94 M146 M15 M08
    N0102 G00 Z3 T010101 SB=1000
    N0103 X146.542
    N0104 G17
    N0105 C5.538 M13
    N0106 G01 Z-10 F1000 M147
    N0107 M146
    N0108 G101 X124.994 C19.842 G41
    N0109 G103 X100 C0 L30
    N0110 G101 X141.421 C315
    N0111 C225
    N0112 C135
    N0113 C45
    N0114 X100 C0
    N0115 G103 X124.994 C340.158 L30
    N0116 G101 X146.542 C354.462 G40
    N0117 G00 Z3 M147
    N0118 M146
    N0119 G95 M12 M09
    N0120 M109
    N0121 G00 X300 Z300 T0100
    N0122 M02
    Mar 2009
    1982
    just curious:
    N0102 G00 Z3 T010101 SB=0
    N0106 G01 Z-10 F0 M147
    the program looks like IGF made. How do You get 0 values there?
    Jun 2008
    372
    Whoops. Fixed now
    Jun 2008
    372
    Also using G137
    DEF WORK
    END
    DEF WORKF
    PF 0,[0,0],100,D
    END
    CLEAR
    DRAW
    N0001 G00 X500 Z800
    N0002 G50 S3800
    NAT01
    N0100 M110
    N0102 G00 Z3 T010101 SB=3183
    N0103 X146.542
    N0104 G17
    N0105 G137 C0
    N0106 G00 X72.929 Y7.071
    N0107 M13
    N0108 G01 Z-10 F2546.4 M147
    N0109 M146
    N0110 G101 X58.787 Y21.213 G41 F509.2
    N0111 G103 X50 Y0 L30
    N0112 G101 Y-50
    N0113 X-50
    N0114 Y50
    N0115 X50
    N0116 Y0
    N0117 G103 X58.787 Y-21.213 L30
    N0118 G101 X72.929 Y-7.071 G40
    N0119 G00 Z3 M147
    N0120 M146
    N0121 G136
    N0122 G95 M12 M09
    N0123 M109
    N0124 G00 X500 Z800 T0100
    N0125 M02
    Jun 2009
    4
    where can i get the Advanced One Touch IGF - L for pc. i have been trying too google it, but whit out any luck
    Jun 2008
    372
    From your Okuma dealer
    Dec 2008
    3109
    Older off-line programming for Okuma was TM-APT ( not on a PC or a Mac, but was a sort of clone of a machine control available only thru Okuma )
    now available is ADMAC for mills and/or lathes for running on a PC---still only thru Okuma
    try searching for "okuma admac" for more info
    Mar 2009
    1982
    sure. A little addition. Both IGF Advanced for PC and Admac are protected by Sentinel based USB (older - LPT port) key
  1. LB 15II osp 5020L
    By MCR-B II in forum Okuma
    Last Post: 10-19-2012, 05:19 PM
  2. Okuma LT15 - OSP7000L HELP.
    By tunitime in forum Okuma
    Last Post: 05-01-2009, 08:51 AM
  3. Okuma OSP7000L Programming help required!
    By zanellan in forum Okuma
    Last Post: 04-21-2009, 09:49 PM
  4. Okuma osp7000l post
    By honk in forum EdgeCam
    Last Post: 09-12-2006, 06:46 PM
  5. help with thread 1/2-8 2star on okuma osp7000l lathe
    By plast744 in forum G-Code Programing
    Last Post: 06-16-2006, 02:23 PM
