I have been away from injection molding for about ten years, so I am wondering if there have been any new developments in flash repair.
Example: simple round container mold, where a round stripper ring forms the bottom of part and ejects it from core. There is a taper on core
OD, and in ring ID, so that the two seat back together for the next cycle. Core material is BeCu, ring is S-7. After X amount of cycles, due to bushing wear,
miss alignment, etc. there is some wear "hobbing?" that develops, allowing flash where the core taper and ring taper meet.
Years ago, we repaired the worn tapers by having them chromed, then regrinding the tapers to fit again. This extended the life of the componets.
I have an oppurtunity to add work to my shop by repairing/replacing worn componets for a new local mold company. I do not have the ability in house to grind these tapers.
So, I am wondering:
1: are there any new materials being used that wear better?
2: is there an alternative to building up with chrome?
what I would like to do is come up with a solution that allows me to "clean up" the core taper, and just replace the stripper ring,
and leave the chrome out completely. This company uses about 5 sets of inserts running in 4 bases, to make the same product.
I would love to "stagger" the taper sizes between sets to allow me to possibly reuse the rings before replacement.
I think I could help keep costs down by turning the tapers as opposed to grinding them, providing I can hold the tolerance.
I would appreciate any input you may have!
