588,504 active members*
4,588 visitors online*
IndustryArena Forum > Community Club House > Computer Power Supply
Results 1 to 14 of 14
    Jun 2007
    24
    Whith the Power Supply again.
    I have a Power Supply from a Dell computer. Does anybody know what the britges on the 20 pin connector that goes to the mother board should be, so The PS can be powered out of the computer?
    Feb 2007
    8
    Talking
    Pinout
    20 PIN MOLEX 39-29-9202 at the motherboard
    20 PIN MOLEX 39-01-2200 at the cable
    Pin Name Color Description
    1 3.3V Orange +3.3 VDC
    2 3.3V Orange +3.3 VDC
    3 COM Black Ground
    4 5V Red +5 VDC
    5 COM Black Ground
    6 5V Red +5 VDC
    7 COM Black Ground
    8 PWR_OK Gray Power Ok (+5V & +3.3V is ok)
    9 5VSB Purple +5 VDC Standby Voltage (max 10mA)
    10 12V Yellow +12 VDC
    11 3.3V Orange +3.3 VDC
    12 -12V Blue -12 VDC
    13 COM Black Ground
    14 /PS_ON Green Power Supply On (active low)
    15 COM Black Ground
    16 COM Black Ground
    17 COM Black Ground
    18 -5V White -5 VDC
    19 5V Red +5 VDC
    20 5V Red +5 VDC
    18 AWG is recommended for all wires except pin 11, which should be 22 AWG
    For 300W configurations 16 AWG is recommended.
    Source: http://www.hardwarebook.info/ATX_Power_Supply
    I hope this helps, if this doesn't the wikipedia article on atx or the spec should answer your question.
    Jun 2007
    24
    Thanks you night. I'll try to set up those connections, but where is the signal I have to give on the 20 pin socket for the PS to work?. I underestand all I should do was to plug the 115 V and rockig and rolling??.
    Jun 2007
    24
    What should I do with the green cable?. I do not know where should it go.
    May 2007
    6
    you need to short pin 13 and 14 for the PS to activate.
    Hope this helps
    May 2007
    6
    The green cable (wire) at position 14 on the 20 pin conector needs to be conected to pin 13. Once you do this the power suppy will work outside the pc. You can use a toggle switch or just directly connect them.
    Jun 2007
    24
    Thanks, I tryed but did not work. I underestand what has to be done is to connect green wire to ground. But the fan makes a first very short run and stops, and does not work anymore unless i disconnect and wait for a minute or so, and then it makes the same. I'm about to give up with the power supply issue. I was cheated twice for people at eBay with two PS's that did not work and I'm trying with this one now. puffff
    Jun 2007
    24
    Ah, and the PS still working if 20 pin connector connected to the mother board.
    thanks guys
    Feb 2007
    8
    If its still working when connected to the mobo, then most likely its not the power supply. Some PSUs also have a switch on the back that turns them on and off that might have something to do with it.
    Hi
    Have a look at this see if it helps, I think you might need to fit a power resistor as a dummy load before it will work.
    http://www.wikihow.com/Convert-a-Com...b-Power-Supply
    Feb 2007
    8
    ^Wow, I've got to try that with one of my old unused psus.
    Jan 2007
    64
    A good trick is if you have an old hard drive, just plug it in to one of the power connectors, and ground the green wire. The hard drive will make enough of a load for the PSU to start.
    Also, if you find that the +12 Volts is low, e.g. 11.5, you need to increase the load on the +5 and/or +3.3.
    May 2007
    6
    Opps sorry, I forgot to tell you about needing a load I just asumed that it was loaded.
    Thanks Audioandy1762 for that link I think I'll build one on the weekend.
    Cheers.
    A lot of older Dell power supplies use different pins than standard ATX power supplies.
    http://www.quepublishing.com/article...e.asp?p=339053
  1. How'd you supply your power supply?
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 08-28-2011, 11:13 AM
  2. More power from switching power supply
    By R.thayer in forum CNC Machine Related Electronics
    Last Post: 03-11-2007, 02:03 AM
  3. Making a good use of Computer Power Supply 3.3, 5, 12, -12 Vdc. Advice needed!!
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 10-25-2006, 12:45 PM
  4. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
  5. Computer power supplies
    By flannman in forum CNC Machine Related Electronics
    Last Post: 12-22-2004, 05:45 PM
