Is this a production situation or a one off?
I've never seen any commercial offering of endmills that will do this. I can well imagine the extreme delicacy of the tip of such an endmill, resulting in a short useful life for the tool.
I would side mill it. For a single job, grind up a flycutter and make a little arbor to hold it in a regular endmill holder. However, grinding the tool requires a sample spline to test the tool shape. If you have a male spline sample, you can cast an inverse off of it with a bit of plaster of Paris, then you've got a gauge to grind and fit the tool to.
For production, you could likely get a tool grinding shop to custom make the tool, using something like a woodruff cutter as a basis to begin from. A small woodruff cutter might get you within 3/8" of a shoulder. If you must get closer to the shoulder than that, you'd almost be looking at some sort of EDM procedure.
