Hello,
After a power outbreak this machine will not turn on, all it does is to show the 3 red error leds being on as well as 1 green at the power unit (see attached pictures for actual error status and error definition from the machine's manual), I have status (H) of that definition.
I have performed the reset process in that manual without luck, have also checked the battery-pack voltage and it seems to be ok. The servo, spindle and turret drives look also ok, their displays are on.
The other power supplies inside the cabinet (100 vac and 24 vdc) have their voltages accordingly. What else can I check? Please help, any and all the help is greatly appreciated. Thanks.
