I'm a Happy Puppy, I fired up my New lathe tonight!
Wow, I fired up my New lathe tonight, it's awsum! :cheers:
I was so happy to find it was a 1:1 lathe, not one of those 1:2 lathes! Everything sounds so sweet, even at 2000 RPM!
I Spent 2hr with a 6' crowbar and a block of metal, lifting each corner and shimming with different thickness blocks and sheetmetal, until I got down to .0015 thick paper! Now that puppy is level!
I ran a 20ft piece of Romex electrical cable to the box on the lathe, just as a temp hookup of 220VAC, then I took a deep breath and pressed the start button!
Wow! It fired right up, no problems!
My new lathe is so clean, I hate to use it, but duty calls!
What I need now is a DRO, or at least the scales for the X & Y axis for now!
The lathe is a 13x40, and does not have a lot of height on the tailstock side of the carrage cross slide, so I will require a low profile unit!
The cross slide travel is 6.875", the saddle travel is 35.25"
My mill has a Mitutoyo KA Counter, I was hoping I could swap the DRO between machines, untill I make enough to buy a second one!
The other item I need is a curved guard to go over the chuck, so the hot stuff doesn't get in my face! What's a good brand?
I will be busy all weekend installaing floresesnt lights, and building the partition down the center of my garage floor!
This is a dream come true! :wee:
Eric
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
