588,495 active members*
4,413 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 and EMC2, need help with setup
    May 2009
    31
    Hi
    Just got a Geckodrive G540 along with a 48volt 7,3amps power supply and four Keling KL23H2100-35-4B steppers.
    I hooked up one of the steppers today to the G540 without a current resistor (read somewhere that it would work ok) and used EMC2 ver. 2.2.8 on an Ubuntu computer.
    In emc2 I used the standard settings for Gecko drivers. Got it working good, but I have a few questions I hope someone could answer.
    In case 1 (attached screenshot with microstep=10) the motor had a velocity of 8550 something (?)when running G0 rapids. Not losing steps I think (how can you see).
    In case 2 (attached screenshot with microstep=2) the motor had an (insane) velocity of 45600 something (??) when running G0 rapids and I could not see the motor loosing any steps. The motor would not run feeds under 700 mm/sec (the emc2 program showed movement, but the motor stood still).
    What is the appropriate microstep setting? I tried both 2 and 10 in the microstepping option as you can see. What does that number mean, an what are the consequenses of changing it?
    May 2009
    31
    Ok, I now realize that the G540 is a static 10 microstepping drive.
    :withstupi
  1. EMC2 Configuration File for G540
    By CoAMarcus in forum LinuxCNC (formerly EMC2)
    Last Post: 06-05-2013, 08:55 PM
  2. G540 & EMC2 Anyone?
    By 725franky in forum Gecko Drives
    Last Post: 04-20-2009, 02:14 PM
  3. trouble with setup of g540 and mach
    By ZNAK in forum Mach Software (ArtSoft software)
    Last Post: 04-05-2009, 02:56 PM
  4. G540 microstepping motor setup
    By mikie in forum Gecko Drives
    Last Post: 03-19-2009, 12:15 AM
  5. g540 setup question
    By don_don in forum Gecko Drives
    Last Post: 02-16-2009, 09:05 PM
