588,079 active members*
5,304 visitors online*
    Aug 2006
    21
    Tooling Falls off Racks?
    I'm currently using a Intermac Masterstone 4000 primarily fabricating granite, mixed with some quartz and marble. Were having some problems when the machine sends the tooling back to the racks. It sends it back fine, but soon as it releases the tooling it appears to stick as the spindle comes up, furthermore knocking the tools off the rack. Weve tried WD-40 on the bits before using them, weve made sure the bits get the proper lubrication, and also changed the time that it picks the tooling up. Turning the Rapid down to 25% at times. Any clue to what could be? My 2nd guess is that the racks are Weighted down so it lifts the racks a bit when it releases.. any suggestions would be greatly apprecaited..
    Chris
    NONN'S GRANITE
    PRAIRIE DU SAC
    WISCONS
    Mar 2006
    1625
    check both draw bar pressure and air presure to unit see if you can increase also did you check rack location?
    Aug 2006
    21
    changed the draw pressure and air this morning. takes an extra 2 seconds or so to ppick up the tool but has not dropped a tool or sent one flying since.. usually happeneds 2 times a day and nothing so far... still got an hour left tho :-) thanks for the help..
    CHRIS
    NONNS GRANITE
    PRAIRIE DU SAC
    WISCONSIN
    Mar 2006
    1625
    it may not hurt to put in a drop or two of oil but check manual first
