587,300 active members*
3,244 visitors online*
IndustryArena Forum > CAM Software > Mastercam > 4th axis tool path depth cuts?
    Jan 2011
    Hey, so I got a problem. I have a profile I want to 4th axis mill, shaped kinda like a tapered cone. Something like the black spike in this image:
    http://images.spaceref.com/news/2003...ike.engine.jpg
    So if I start with a solid barstock blank, mastercam wants to plunge full depth and do the whole cut at once. I want it to take off nibbles. Should I just manually programing my own rough passes, or is there an option for multiple passes to final diameter on 4th axis contour parts? thanks!
    Feb 2011
    Hi Clivefx,
    Did you ever figure out a way to do this? I've been wondering the same thing for a few weeks now!
    Jan 2007
    1389
    If I remember correctly it depends were your z0 is, you adjust that in your tool profile on how deep to cut. I had the same problem on one 4th axis job and it took me a very long time to figure it out( I ended up offsetting it in the machine). once I figured it out it was stupidly easy. that was a long while ago and cant remember exactly what I did.
    May 2011
    62
    I also am curious about how to do this.
  1. Same tool - different cuts ?
    By hmc710 in forum Colchester Tornado lathes
    Last Post: 07-25-2010, 08:10 PM
  2. 4-Axis CAM and Tool Path Problem
    By skibbey in forum Uncategorised CAM Discussion
    Last Post: 03-13-2007, 04:05 PM
  3. MCX depth cuts question
    By charper in forum Mastercam
    Last Post: 02-07-2007, 05:46 AM
  4. C axis tool path
    By Capt Crunch in forum Mastercam
    Last Post: 12-21-2006, 02:05 AM
  5. need help fast 5 axis tool path in mastercam
    By fasttom in forum G-Code Programing
    Last Post: 12-02-2005, 07:22 AM
