1. Machine was purchased June, 2012, just pass the one year warranty. This is a six months problem that I had with this 2012 Haas VF-1
2. For the past six months, Haas Tech has show up 4 times, replaced the Z axis top mount and bottom bearing twice, change some parameter setting, problem seems to go away whenever they done the service with it. It is an intermittent problem, tough to trouble shoot.
3. Z axis Way cover has been cleaned and check it out good.
4. Haas Tech inspected the Ball Screw Assembly and linear guide looks clean, grease lube is plenty
5. Machines still cutting part with excellent result, it all looks normal until you get this screeching noises now and then.
6. As Aug 15, 2013, the screeching noise become more constant, (see the atached video)
7, Next move is replace the Servo Motor, see if help in anyway.
If anyone had experienced similar issue, need your input, Thank You
