I have the opportunity to pick up some really fancy super precision ballscrew bearings that normally cost around $800, for peanuts. The problem is that they are 25mm ID. The ballscrew I will be using has a 20mm diameter. Is it feasible to fit a ground spacer with a shoulder? If so where can I get one from?
