588,397 active members*
4,687 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Xilog3 - how to create a mix help please
Results 1 to 8 of 8
    Jun 2011
    24
    Hi
    I have never been able to work out how to create what i believe to be called a mix, basically bring up a mix which will run 2 .pgm files one after the other i.e. machine one side flip board and machine the other without aving to bring up the pgm programs seperately
    Thanks for any help
    Cheers
    M9G
    Re: Xilog3 - how to create a mix help please
    In Xilog, File > New, and select .mix for the type.
    I don't have it in front of me, but on our version, you select the last option from I think the 3rd menu item, which let's you select your files.
    It's something like Insert...List of Programs. I can give you a more accurate explanation tomorrow.
    Jun 2011
    24
    ok thanks, yeah if you wouldnt mind please
    Cheers
    New file, and choose "mix" as the type.
    Then Tools > List of Programs to select the files to add to the mix.
    Note that the "List of Programs" option isn't available until you choose to create a new mix file.
    Jun 2011
    24
    Hi thanks for that, are you using xilog plus as those options you suggest aren't available in xilog3, there is no file tab to click on
    Cheers
    Yes, Xilog Plus V1.12. It's probably 8 years old.
    Jun 2011
    24
    Ok well thanks for taking the time to reply really appreciate that but xilog plus is different to xilog3, you dont get a file tab
    Cheers
    Service SCM BR Guest
    m9g, Hi You managed to create a mix of programs?
    Via iPhone of the Tapatalk
  1. Replies: 1
    Last Post: 01-04-2015, 03:10 AM
  2. need help mastercam x5 to xilog3 num control mobidelli 427
    By cncnewbies in forum Post Processors for MC
    Last Post: 11-16-2011, 04:37 PM
  3. Record 130, Xilog3 and Programing
    By dnormand25 in forum CNC Machining Centers
    Last Post: 07-31-2011, 02:12 PM
