588,224 active members*
4,072 visitors online*
    Dec 2006
    21
    motor overload
    Hello all,
    I have a VMC20 that gives an alarm and shuts down while doing helical interpolation (cutting threads). This problem is intermittent, but it happens often enough to be a PITA. When it goes into alarm, I send it home, cold start and resume operations for a while. At times it will be run fine for several hours. This all started a couple years ago, but seems to be getting worse with time. I replaced all 3 resolvers this past summer and thought that the problem was fixed, for a while, then it started doing it again. Regular circle interpolation has not been a problem. Replacing the resolvers improved the accuracy on cutting round holes and surface finish. I have also replaced the X & Y ball screws & bearings.
    I am at a loss at where to look next.
    Thank you in advance!
    Gary LaValley
    May 2011
    11
    Best advice I can give you is to call Sam Mckinney, he is the owner at Bluegrass machinery in Ky. Sam is a great guy and can usually tell you what's wrong with the machine over the phone. I have Fadals and Sam is the only person that I allow to work on them.
    Mobile # 1-606-260-1322
    good luck
    Arlie
  1. Hydraulic Motor Overload.
    By Temo in forum Cincinnati CNC
    Last Post: 10-18-2012, 05:49 AM
  2. 4525 motor overload
    By charliemisa in forum Fadal
    Last Post: 02-21-2011, 09:15 PM
  3. error #8 motor overload
    Last Post: 04-07-2010, 05:19 AM
  4. C Axis Motor Overload
    By Paul Petersen in forum Fadal
    Last Post: 12-19-2007, 01:11 PM
  5. spindle motor overload
    By RdHawg in forum Uncategorised MetalWorking Machines
    Last Post: 12-06-2006, 08:02 PM
