588,671 active members*
6,187 visitors online*
    Mar 2014
    8
    Tailstock quill doesn't move
    I got the Hwacheon Hi Tech 300 2007 year but can't force the quill to work by footswitch. What could be the cause? Footswitch changed. Thanks in advance.
    P.S. I have no docs except Fanuc 18i-TB.
    May 2015
    70
    Re: Tailstock quill doesn't move
    Check for setting on Software Operators Panel to enable tailstock.
    Mar 2014
    8
    Thank you Mike. It works. But the quill moves even when spindle rotates. Is it correct?
    May 2015
    70
    Quote Originally Posted by wiker View Post
    Yes, that is correct. Tailstocks don't normally have interlocks related to spindle running. Some have limit switches inside them that can be adjusted to confirm that the quill is in the right place. Meaning not out too far or not out far enough.
  1. Tailstock quill condition alarm
    By Paul.B in forum Okuma
    Last Post: 04-04-2012, 12:55 PM
  2. 7x powered tailstock quill
    By blades in forum Mini Lathe
    Last Post: 05-07-2011, 07:30 AM
  3. Quill is hard to move up and down
    By Billdog103 in forum MetalWork Discussion
    Last Post: 04-26-2011, 05:10 PM
  4. t32 311 C15 Error (Tailstock Quill)
    By apylus444 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-23-2008, 03:03 PM
  5. A suggestion for tailstock quill not advancing
    By bdyenter in forum Daewoo/Doosan
    Last Post: 10-18-2007, 04:37 AM
