588,658 active members*
5,295 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > G-code ploter with line number annotated?
    Aug 2005
    29
    Could some one recommend a ploter that marks the respective line number
    on the plot? I have some G-code and I want to adjust the feed rate at
    acute angles. It is hard for me to look at the G-code to figure out where
    the angles are.
    BTW, is there free or low cost software I can use to do the feed rate
    adjustment according to some parameters I set?
    Thank you very much.
    Apr 2005
    3634
    Try, www.NCPlot.com
    Check out the latest Beta version.
    What you do is load your g-code file into NcPlot, after it plots the code, click on the part of the plotted line that you want to change the feedrate, then Ncplot will highlight that exact line of code in the textbox. Then just change your feedrate etc...
    Sep 2004
    38
    Try www.ncmanager.com
    Possible do also.
    Possible write the condition and get the list of all necessary lines.
    Jun 2003
    205
    Auto Feedrate Adjustment Software
    Take a look also at KipwareXC conversion software ... www.KentechInc.com
