588,199 active members*
4,739 visitors online*
    Mar 2008
    9
    Idea for a small router
    I´m planing to build a small router to cut basla and plywood, Ithink to use "T" and "L" aluminium section as guides and slides made of HDPE, Wath do you think abouth this?, I will need .004" of accuracy.
    Mar 2004
    1661
    I think they'll flex and wear faster than you think. I would suggest looking up all the proven designs, you'll find most of them in the desktop mill forum.
    Best regards,
    Sven
    Quote Originally Posted by svenakela View Post
    Best regards,
    Sven
    Don't you mean the DIY router forum?
    Mar 2008
    9
    Best regards,
    Sven
    I´m planning to use 1/8 or thicker section and 6061 t6 or maybe 7050 /7075 t6, do you thick that this could flex?
    I even could use 1/4" steel, I think this design coul very easy to build, if I could make it stiff enought!
    P.S.: excuse muy very bad english :-(
    Mar 2004
    1661
    There too, and here too!
  1. A Small Lathe Router
    By Clockwork in forum Open Source CNC Machine Designs
    Last Post: 12-27-2007, 04:46 PM
  2. Crazy idea - Sherline headstock on wood router?
    By Rhodan in forum Benchtop Machines
    Last Post: 11-05-2007, 01:49 PM
  3. New Idea 4x8 Router Table
    By jeffg in forum CNC Wood Router Project Log
    Last Post: 05-22-2007, 02:58 AM
  4. MastercamX and small K2 CNC router
    By Ed Williams in forum Mastercam
    Last Post: 03-30-2006, 08:33 PM
  5. Router Idea and Questions
    By Bruggles in forum DIY CNC Router Table Machines
    Last Post: 02-02-2006, 04:08 PM
