588,603 active members*
9,800 visitors online*
Hybrid View
    Dec 2005
    59
    Help with steppers
    Hi, Very new to CNC, I have three stepper motors that were given to me some time back and I'm hoping that someone can help me with specs for the motors.
    The label states: Japan Servo Co Ltd, KP56LM2-097. DC6V. 1.8 deg/step.
    They are Nema 23 size and have two shafts. They also have six wires, red, red-white, green, green-white, black and white. The black and white wires don't seem to have been used - they're taped to the other wires which go to a connector.
    I would like to use these in a small CNC machine that I hope to build from plans that I found on the CNC Zone.
    I tried to contact Japan Servo and a couple of their agents but have not received a reply.
    Thanks in advance for any and all help you can give me.
    Wally
    Googling "Japan Servo Co Ltd, KP56LM2-097" returned this:
    http://www.eio.com/public/stepper/1366.html
    Dec 2005
    59
    Gerry,
    Thank you very much-looks so simple when you know how to find the information. I hope to use my machine to cut model airplane parts. I am collecting material for the build and was hoping that the motors could be used. I think it looks like they can. Any suggestions on what plan to use for a first machine?
    When they spell out the wires, the black one is not used? And the white wire is used for the center tap on both phases?
    Is there a primer on how to set all this up? Sorry to sound so stupid.
    Wally
    May 2006
    4
    Wallyh... Did you ever get your foam cutter up and running?
    I am currently working on a foam cutter now.
    I have the same motors as you. Any ideas that you have would be greatly appreciated.
