has anyone who uses a 440 tormach actually used a 770 and compared the results of these 2 mills? is the surface finish the same running the same machining job in each? did you encounter a lot more tool chatter with the 440? were you able to adjust the feed and speeds to work out the tool chatter etc. ?
