588,295 active members*
4,719 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Demo Mode saved drawing
Results 1 to 9 of 9
    Mar 2006
    35
    I have a drawing that I saved in demo mode, now that I have a registered version of BCC v23 the drawing won’t open. I'm getting this message, "The part was saved in demo mode, Unable to load in a license version." Is there some way around that or do I need to redraw in the license version?
    Apr 2007
    243
    You need to redraw the part.
    Dec 2007
    496
    The bold writing is pretty self explanatory. It does seem kind of dumb though that if you evaluate something, design something, then buy the product, you lose all the info.
    Mar 2006
    35
    That sucks! Thanks guys
    Jun 2008
    1838
    This could be worth a try!!
    Try opening V23 without the "dongle" and then try opening the original drawing with V23 in Demo Mode.
    If it will open in Demo Mode and if it is just the geometry you need then you should be able to highlight all the geometry and then copy it to the Windows "clipboard".
    Once that`s done then close BobCAD fully and then plug the "dongle" in and open BobCAD again and you should be able to "paste" the geometry into a new blank drawing!
    You won`t be able to bring all the Features and toolpaths etc but if you have the geometry then it isn`t hard to redo the features!!
    Worked for me with my BobCAD!!
    Regards
    Rob
    Mar 2009
    13
    Well ity would not be fair that you can draw in demo not owning a seat and then send it to someone who has bobcad somwhere else.
    Jun 2006
    241
    Here's the stupid thing. After I pulled the dongle out, I accidentally saved a drawing that I had done with the dongle in. It saved it in demo mode. Now it won't let me open it in licensed mode.
    Apr 2005
    47
    I've had this happen a couple of times.
    1) Open file in demo mode, select all, then copy.
    2) Insert dongle, re-launch program in licensed mode
    3) Paste geometry into a new file
    4) Save and you're done.
    Jun 2006
    241
    Thanks for the tip. That definitely helps. I still lost all of the CAM tree work, but on this drawing I was going to redo the tool paths anyway.
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 01-20-2024, 10:34 AM
  2. demo mode v23 why is it saying im in demo mode
    By chaz6966 in forum BobCad-Cam
    Last Post: 03-17-2009, 11:32 PM
  3. Hypermill 5.1 DEMO MODE only. Help?
    By Hemmi in forum Hypermill
    Last Post: 11-29-2008, 08:03 AM
  4. NcPlot could have saved my butt
    By Karl_T in forum NCPlot G-Code editor / backplotter
    Last Post: 08-30-2006, 12:51 AM
  5. X in demo mode
    By mdlmkr in forum Mastercam
    Last Post: 10-28-2005, 02:53 PM
