TTS compatible tooling for 2-3" deep pocketing ops?
First off, there is no way I would try to mill a pocket 2 to 3 inches deep. I would create a hole pattern and drill most of the stock out then use your end mill or whatever cutter you choose to finish the sides and bottom.
Depending on the size of the pocket you need to make, it could take hours to make it that deep with an end mill, but you could drill it out on minutes.
If you want to use a 3/4 inch end mill, fine, use a drill to make a 3/4 inch hole, then use your 3/4 inch end mill and make .200 stepovers to plunge ruff and you'll move more material than you ever would by side cutting with an end mill.
I know it works, I have several repeat jobs that I do this way. One particular job takes 36 minutes to side cut with an end mill, and it takes 11 minutes to plunge ruff and finish, and I do it all with the same cutter.
You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
