Hello All,
I have a job with multiple diameter step drilled holes. The material is 316L SST, there are 3 different diameter holes at the same position... Hole 1 is a .3125 diameter 6.71 deep, hole 2 is a .500 diameter 4.75 deep and hole 3 is a .625 diameter 2.75 deep... We are going to use coolant thru carbide drills in a Mori Horizontal... My question is, in what order I should drill these holes (big to small or small to big)? Any feed back would be appreciated...
