586,535 active members*
3,139 visitors online*
Page 4 of 5 2345
Results 61 to 80 of 86
  1. #61
    Jul 2013
    230
    Re: Vetric Aspire nose dive on Z Axis
    Quote Originally Posted by adam_m View Post
    Just my two cents here, without reading the entire thread but if it's loosing steps which is what your last photo looks like to me, it may be the driver for the axis. The reason I say this is that because I have a G540 and for a similar reason my Z kept loosing steps and ultimately it turned out to be a faulty driver causing the issue.
    Is there a way you can swap the axis drivers, cables, steppers for comparison to each other?
    Adam,
    I’m not sure what you mean about swapping.
    Do you mean disconnect the boards in the controller box?
    I’ll tell you what, I do remember a while back, I had a problem and I jiggled the big protective tube the cables are in and it worked. So now you got me thinking I may have a frayed cable.
    That’s good direction.
  2. #62
    Oct 2004
    94
    Quote Originally Posted by robwiacek View Post
    Swapping just means to use a particular componend in a different x-axis position and see if the bad behavior exists in the new poistion after the swap. If the problem moves when you've moved (i.e. swapped) the component, then the component you've moved is faulty.
  3. #63
    Jul 2013
    230
    Quote Originally Posted by Arjay View Post
    Component?
    Different program
  4. #64
    Jul 2013
    230
    Component?
    Different program
    Component could mean a few things to me.
    Different tool
    Different program
    So I’m not sure what your saying.
  5. #65
    Sep 2005
    1740
    Swap parts (exchange) around to a different X is now Y and etc.. Your planning to teach?
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
  6. #66
    Oct 2009
    759
    Component?
    Different program
    Different tool
    Different program
    Yes, a tool or a few other things like a driver or a stepper are all components of the machine.
    You swap them with another to trouble shoot an issue.
  7. #67
    Jul 2013
    230
    Quote Originally Posted by wmgeorge View Post
    Here’s a problem.
    28’ radius into a 22” diameter circle.
    How deep will that make the dish?
    You have 10 seconds.
    Start ..... now
  8. #68
    Oct 2004
    94
    Component?
    Different program
    Component? Um, electrical parts that make up the machine? Move them around to see if you get a different result. You know, like basic troubleshooting?
    trou·ble·shoot
    [?tr?b?l?SHo?ot]
    VERB
    troubleshooting*(present participle)
    solve serious problems for a company or other organization.
    trace and correct faults in a mechanical or electronic system.
  9. #69
    Jul 2013
    230
    trou·ble·shoot
    [?tr?b?l?SHo?ot]
    VERB
    So first thing I’m going to do is retire the motors.
    Years ago I had a motor that didn’t work, then I giggled the long protective shield on the wires and bam! It worked.
    I bet that’s it.
    After that I’ll try changing drivers.
    And so on and so forth.
    Thanks for your help.
  10. #70
    Jul 2018
    6402
    2.25 inches, wrong yes I see that error now. Peter hard to see " vs ' sometimes.
  11. #71
    Dec 2003
    1230
    2.25 inches
    I believe the entirely spurious challenge involved a 28 foot radius.The OP has a rather individual way of asking for advice and then acting on it.I have to wonder if there are other background issues of some sort.
  12. #72
    Jul 2013
    230
    [QUOTE=peteeng;2302786]2.25 inches[/QUO]
    .1801 is the correct answer.
    28’ radius in a 22” wide dish what us the depth or height.
    This was directed a a contributor with an amazing snarky attitude.
    He said to me... “and you’re going to teach”?
    Eh wm....?
  13. #73
    Oct 2009
    759
    wm.... is a very valuable contributor to this forum.
    The fact that you know the answer to a question you asked yourself does not necessarily mean much.
  14. #74
    Sep 2005
    1740
    When I was teaching I knew what I was doing. I taught my students troubleshooting and how to swap out parts if needed to solve a problem. They now have jobs in the real world, some of them are darn good, better than the teacher!
  15. #75
    Jul 2013
    230
    Quote Originally Posted by davida1234 View Post
    The oddity is he insults me for being a teacher?
    The beauty is ... I’m trying to teach boys in jail an honest option to dealing heroin.
    This will be the way.
    I just purchased Vetric Aspire.1995
    “. “. “. 2 MACH 3......... 350
    Various parts for my build totaling $4700
    I’m pretty committed to my calling.
    I don’t need tounge in cheek, snide remarks.
    Just help.
    Isn’t that what this site is for?
  16. #76
    Oct 2004
    94
    Just help.
    I'm not an expert here but have a fair amount of time answering questions on an unrelated programming forum.
    One of the most frustrating things in attempting to help someone is when the person asking for help doesn't follow the help they are given. After seeing an op repeatedly ignore advice, it becomes difficult to keep the snark out of the responses.
  17. #77
    Jul 2013
    230
    How do you know what was followed
  18. #78
    Oct 2004
    94
    How do you know what was followed?
    If advice was followed it would be helpful to indicated as much in the replies, don't you think?
  19. #79
    Sep 2005
    1740
    And having successfully taught for a number of years (12) and starting a computer lab for my own students I had to use hand me down computers that came from the CAD lab with Zero software. I installed legal copies of AutoCAD LT on all 20. You will soon find your one legal copy of Aspire and one computer is not going to work for 10 students.
    PS There is a much greater need for machinists and welders than someone who can run a CNC router. They could be taught to weld in a few weeks of classes.
  20. #80
    Jul 2013
    230
    The Vetric Aspire license at $1995.00 includes 40 seats.
    I’m sure you don’t know anything about my program.
    The boys are court ordered. It is a 24/7 facility with sentences in the range of 6-18 months.
    Reading and math levels for these high school age boys are around 3-4th grade. Most if not all have traumatic related injuries, both mental and some physical (or abuse). Most are on meds for ADD and other physiological issues
    So, in order to “hook” them, we need quick positive reinforcement.
    Welding is one of those programs I teach that gives them the quick hit.
    But, the CNC work, designing a simple box or rubber band power car, is exactly that! A quick hit.
    Most of these boys sell or do drugs or both!
    So the issues we have to juggle are sometimes overwhelming.
    I give any other “shop teacher” a week with these boys and they’ll crumble.
    It’s not easy, but out of 140 we may get 5 to go on to college or trade school.
    Hope the insight helps your understanding of another world many will never venture into.
Page 4 of 5 2345
  1. VETRIC ASPIRE - TROUBLE
    By forbri40 in forum Aspire
    Last Post: 01-24-2018, 04:03 PM
  2. Vetric Aspire V CNC
    By KWK in forum Commercial CNC Wood Routers
    Last Post: 09-14-2017, 10:18 AM
  3. Aspire from Vetric vs. Aspire from Alphacam
    By jooooooe in forum Aspire
    Last Post: 06-04-2015, 04:52 PM
  4. setting up tool in vetric aspire
    By ttharp in forum Uncategorised WoodWorking Machines
    Last Post: 03-02-2014, 12:56 AM
  5. Rotary axis - NcStudio - Aspire
    By Nidge888 in forum Chinese Machines
    Last Post: 04-05-2012, 04:13 AM
