587,787 active members*
2,737 visitors online*
Results 1 to 7 of 7
    Oct 2004
    Talking cnc control software for windows xp
    Hi to anyone,
    I'm new at this so please bear with me. I'm in the process of setting up a desktop system, and at the present time, my main concern is with control
    software,using a windows xp operating system. Is windows a good way to go?
    Also, is the Mach2 control software good stuff? I've heard that it is.
    Ralph Burge
    Jul 2003
    45
    Hi Ralph and welcome
    1: What type of drive motors will you use to power your system, stepper motors or dc servo motors.
    2: Why use a powerfull laptop or PC with windows XP to do a simple job that can be done with that old 486pc? You've probably got one tucked away under your bench in the workshop (or if you don't have one you can get one on ebay for $30).
    mike potter
    If you want to use Windows XP, Mach2 is really the only reliable option using the parallel port. If you're going to use Mach2, though, it really should be with a dedicated computer for running a machine only. You could also use TurboCNC under DOS, and set up a dual boot system with XP. Or something like DeskCNC, which uses the serial port and an external board to provide step and direction, which will run under any windows (98 and above).
    Jul 2007
    thanks
    Jan 2008
    5
    What about Delcam, SolidCAM, SmartCAM, GibbsCAM, they all work with windows XP .
    Quote Originally Posted by rykegrey View Post
    They don't control machines. They just create code for the controller to run.
    Thanks for the laugh.
  1. Stepper control software suggestions
    By jlawren6 in forum Uncategorised CAM Discussion
    Last Post: 05-21-2011, 11:42 AM
  2. Augh. Too many choices in CNC control software
    By MadMax in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-08-2005, 07:00 PM
  3. ***One stop CNC software guide***
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 05-27-2004, 10:31 PM
  4. MACH 1..the BEST choice in affordable software for CNC control
    By CNCnUtZ in forum Mach Software (ArtSoft software)
    Last Post: 02-15-2004, 06:16 AM
