588,638 active members*
5,391 visitors online*
IndustryArena Forum > CAM Software > Mastercam > HELP Mastercam X2 toolpath problem
    Jan 2008
    5
    I have in X version use Angle Aggregate to machining the 2D contour toolpaths not to have the question,
    similar method use when X2 version the Backplot cutting tool direction is not right. Is in the X2 version something must be set.
    If you want it to look like mr1 set the toolplane in your contour to top, not front, you are cutting from the front in mr2.
    Steve
    www.cad2cam.blogspot.com
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    Sep 2007
    217
    In the older version you did not have to define the tool in the Machine Manager when doing aggerate head work. In the newer version you must 1st define the tools in the Machine manager, then select the angle head in the tool manger. To do this you right click in the tool manager and the right click options will have it.
    Jan 2008
    5
    Thank you the reply,I find that in the X2 version if check the option "Translate NCI coordinates to Machine View with aggregate the" in Control definition , then the problem that cutting tool direction is error will occurred. But it is no problem in X version.Is there the solution.
  1. V9 Toolpath Problem
    By Clawsie Machine in forum Mastercam
    Last Post: 12-01-2007, 08:34 AM
  2. Replies: 1
    Last Post: 07-23-2007, 05:57 PM
  3. 4th Axis Toolpath with mastercam
    By rcrabb in forum DIY CNC Router Table Machines
    Last Post: 01-07-2007, 03:41 AM
  4. MASTERCAM 9.1 TOOLPATH GENERATION for Mach3
    By chris59 in forum Mach Software (ArtSoft software)
    Last Post: 11-18-2006, 05:58 PM
  5. need help fast 5 axis toolpath in mastercam
    By fasttom in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-02-2005, 06:51 AM
