Hi guys,
I've got an issue at work on our Mori Seiki SL-25 when trying to create a canned cycle for a face grooving operation. There's a pocket in the face groove - cutting out the webbing on a pulley so there's an undercut that starts at the top and continues down to a boss.
We're using G72 with all the usual PQUWF commands but instead of roughing out, it goes straight to the finished profile - like it's just read a G70 command. On our Hitachi Seiki, we just input a regular G72 line, but add an "R" value to the syntax. Is there something similar on the Mori Seiki? We have enabled parameter 8110 (G71/G72 pocketing). Our local representative isn't much help.
We don't use Cad/Cam and write all programs manually, so canned cycles are (usually) our friend.
A brief sample of the profile reads something like this:
G00 Z-17.5 X235.0
G01 Z-18.0
X200 Z-24.0
X150 Z-30.0
X70.0
G03 X50.0 Z-20 R10
Z-18.0
I've omitted everything just so you can see the basic profile. The 50mm X position is a boss that extends out to Z0.0 (hence the pocketing)
I hope that makes sense and someone can show me the correct syntax!
Thanks in advance for any assistance!
