![Quote](images/misc/quote_icon.png)
Originally Posted by
WarrenW
I am just starting to learn to use Mach 2 before I have my cnc router complete. I have 2 questions.
1. Where in the software do I setup the leadscrews I am using? I am using 1/2-10 Acme screws.
2. One thing I want to do is cut out letters in thin wood. I used one program to save letters as DXF and then i converted them to gcode and then loaded it into Mach 2. When i run it and watch it cut, for letters like A, B, D, etc. it cuts the outside of the letters first and then the inside. Won't I need the inside cut first? Otherwise, the letters will not stay down if they are cut loose from the wood for the inside to be cut out. Any suggestions?
Thanks!
Warren
