588,687 active members*
5,693 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Whats meant by Module 1.5 and 1.0 when referring to rack (and pinion)?
Hybrid View
    Oct 2015
    17
    Jun 2010
    4262
    Re: Whats meant by Module 1.5 and 1.0 when referring to rack (and pinion)?
    Spec for the size of the gear teeth. Try Wikipedia under Gears.
    Cheers
    Roger
    It's the pitch of the rack. Pi x module.
  1. Power supply with transformer and rack & pinion module 4
    By CNC_Amateur in forum DIY CNC Router Table Machines
    Last Post: 12-03-2015, 09:19 AM
  2. calculatiing pinion size for rack and pinion setup
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 08-06-2015, 11:18 AM
  3. Replies: 3
    Last Post: 05-05-2015, 04:16 PM
  4. Ballscrews or rack and pinion? What module of rack and pinion is the best?
    By masinecc in forum DIY CNC Router Table Machines
    Last Post: 04-13-2015, 06:04 PM
  5. module 2 rack and pinion
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 03-05-2008, 02:25 PM
