587,086 active members*
2,900 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc SRAM card driver for windows XP
Results 1 to 11 of 11
    Oct 2010
    I need driver for SRAMcard which will work on windows Xp.
    If have plz help.
    thanks.
    Nov 2007
    188
    sram card
    Check out this link just went through this at our shop these are 16 bit cards and most newer computers are 32 bit good luck or call Memex and talk to Gram Young (1-905-635-3043) and the can get you a card reader that hooks up to a usb port and will work with any computer for $195. that what we ended up doing if you have a older computer that still has the 16 bit card slot you may or may not get it to work the link below has some helpful info.
    PCMCIA SRAM PC Cards Memory Card Devices FAQ, Synchrotech
    Dec 2009
    14
    SRAM and Windows XP Work Around for PC Card SRAM
    SRAM Cards do not come with drivers, it has always been the OS vendor's responsibility to
    include support for these devices. Unlike previous versions of Windows, SRAM drivers
    traditionally included on Windows distributions are not included with Windows XP. The
    following information explains a work around to get Windows XP to recognize and use PC
    Card SRAM. Be certain Windows XP is up to date with the latest Service Packs and the host
    hardware correctly supports PC Cards.
    Please note that Pretec provides this work around as a customer service and does not
    guarantee that will work with every system configuration.
    1. Insert the SRAM card into the PC Card slot
    2. When the 'Hardware Wizard' appears, select 'Install from a list or specific location
    (advanced)'
    3. Click 'Next'
    4. Select 'Don't search I will choose the driver to install'
    5. Click 'Next'
    6. Scroll through the list of choice and select 'PCMCIA and Flash memory devices'
    7. Click 'Next'
    8. Double click 'generic' under the Manufacturer listing
    9. Select 'Generic PCMCIA Memory Card' from the Model listing
    10. Click 'Next'
    11. Click the 'Yes' button when the warning dialog appears, to dismiss it
    12. Click 'Finish' when the 'Completing the found new hardware wizard' dialog appears.
    13. Restart Windows
    Oct 2010
    hi cncman007,
    my problem is the Hardware wizard does not appear on screen.
    Dec 2009
    14
    pm sent
    May 2008
    4
    Dear cncman007,
    If i buy a PCMCIA SRAM memory card + Card Reader,
    does it possible executing a nc program from PCMCIA SRAM memory directly on the fanuc 18m control? liks as fanuc 21im control using ata flash card.
    thanks
    zxcvbn
    SRAM Card Support
    Please visit CNC Monitors Repairs, CNC Monitors Replacements
    for all support queries
    Quote Originally Posted by zxcvbn View Post
    Dear cncman007,
    thanks
    zxcvbn
    Feb 2009
    6028
    Quote Originally Posted by cncman007 View Post
    (advanced)'
    3. Click 'Next'
    5. Click 'Next'
    7. Click 'Next'
    10. Click 'Next'
    13. Restart Windows
    Agree, however sometimes you need to actually call it the sentinal card. Found that to work 99% of the time.
    Mar 2008
    7
    Re: Fanuc SRAM card driver for windows XP
    (advanced)'
    3. Click 'Next'
    5. Click 'Next'
    7. Click 'Next'
    10. Click 'Next'
    13. Restart Windows
    This worked for me with a Pretec 2MB SRAM on WXP. Thanks for posting.
    Jan 2011
    350
    Works with WinXP, but for Windows 7, anyone have a clue if it's possible to use them?
    Jan 2011
    350
    Quote Originally Posted by botha.y View Post
    Answer to that is yes, but only with an actual SRAM PCMCIA to USB card reader.
  1. SRAM card reader
    By Hames in forum Want To Buy...Need help!
    Last Post: 11-25-2013, 01:09 PM
  2. CF card SRAM backup/Restore issue
    By elab.ess in forum Fanuc
    Last Post: 04-21-2013, 01:38 AM
  3. fanuc 210i-T sram problem
    By P3ki in forum Fanuc
    Last Post: 03-29-2013, 02:08 AM
  4. FANUC SRAM Memory Expansion
    By Aaron liang in forum Fanuc
    Last Post: 03-26-2012, 05:40 AM
  5. Windows driver for PMAC2-PC ISA card
    By =aike= in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-29-2010, 03:09 AM
