Originally Posted by
52 Degrees
Hello,
I have a laser cutter using the mpc6515 leetro board. The machine was running a job and just stopped half way. When I turned it back on the screen just said 'system starting please wait' and was stuck there.
I thought if I reinstalled the firmware using the memory stick it would work again, however after doing this, turning it off and then on again there were no lights on the main board at all and the LCD no longer turned on.
Do think im going to need a new mpc6515 board and a new PAD03-e panel or do I just need a different firmware to install? or is it just the TOSHIBA ULN2803APG chips that need replacing?
