586,076 active members*
4,119 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > Help with RhinoCam Pro
Results 1 to 9 of 9
    May 2007
    125
    Could not get help with the last thread so I am trying again. I do not know why Rhino-Cam will not let me select this file as my stock is there limitations to what you can use?
    Attached Files Attached Files
    Apr 2004
    5737
    While we'd like to help
    Nobody wants to open your unknown zip file. That's a can that can be full of worms. If you're using a legal copy of RhinoCAM Pro, try sending your file to Mecsoft support and see what they say -support is free, and there are no "maintenance" payments required to get it. There's probably something wrong with your file, but they'd be the folks to tell you what that is.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Quote Originally Posted by Astroguy View Post
    May 2007
    125
    Quote Originally Posted by awerby View Post
    Andrew Werby
    I will try there forum as well but here is the file as DXF.
    Aug 2010
    599
    Well the first thing I noticed is that your .dxf contains only a wire drawing and it seems choosing stock from selection requires a solid. So I just revolved your wire model and created a solid then it let me choose it as stock from selection.
    May 2007
    125
    Quote Originally Posted by SWATH View Post
    Thanks for helping me, the original Rhino file is here http://www.cnczone.com/forums/rhinoc...tml#post867579
    and it is a good file I must be doing something else worng I am new to Rhino and Rhinocam and do not get a chance to use it very much I saved it as a DXF file so I could post it here no one would open my zip file in the other thread I quess they did not trust me but that is the only way to post a Rhino file. If you could check my orignal file it would be great!
    Aug 2010
    599
    Ok I opened your .3dm file and there was no stock, then all I did was select your model>click stock from selection and there was stock the same shape and size of your model. If you move the model out of the way you should be able to see the stock.
    May 2007
    125
    I do not know why it does not work for me I can draw any other shape and it will select it but I still can not select this one. Could you post the file back here with it selected as stock so I can open it and see if it is still selected as stock? Thank you so much for this help!!!
    Aug 2010
    599
    Sure no problem. Since I can't upload a .3dm I just changed the extension to .pdf. When you download it just change it back to .3dm then open it with Rhino.
    May 2007
    125
    Thanks that workd fine, I am going to have to call tech support to see whats going on.
  1. RhinoCam Help
    By Micro Rotors in forum Rhino 3D
    Last Post: 09-12-2007, 03:11 PM
  2. RhinoCAM Help ... It's Gone!
    Last Post: 08-29-2007, 05:42 PM
  3. RhinoCAM PRO
    By CAM USER in forum News Announcements
    Last Post: 09-07-2005, 10:05 PM
  4. RhinoCam
    By CarveJunky in forum Rhino 3D
    Last Post: 06-19-2005, 02:27 PM
  5. RhinoCam
    By Dogsione in forum Visual Mill
    Last Post: 01-26-2005, 06:09 AM
