588,676 active members*
6,441 visitors online*
Results 1 to 15 of 15
    Dec 2004
    86
    Endmill runout
    Wondering what everyone thinks is an acceptable amount or runout for a 1/4" dia endmill. Is there a standard way to measure runout on an endmill? Does one just check the highpoints on the flutes? the bottom of the shaft before the flutes start? etc.
    I ebay'd some endmills for next to nothing but alot of them seem to have a fair bit of runout. Like a hundredth measured an inch from the end of the collet on the shaft. Is it a mistake to assume that the shaft should be straight an circular, after all as long as the flutes are in line with the part of the shaft thats in the collet what does the accuracy of where im measuring matter? Anyways, I'm just a newbie to this and hopefully some of this will make sense to someone more experienced.
    Also, I checked the runout on on the collets, its not perfect but its decent enough that its not the cause of all that wobble in the endmills.
    Nov 2004
    260
    Usually this is much worse on resharpend endmills.
    Makes it harder to measure the dia. a endmill will cut.
    It also shortens the lifespan of the endmill because only
    one of the flutes will see most of the cutting and become
    dull much sooner.
    Jan 2004
    3154
    The best method is to make test cuts and measure the cut geometry.
    High precision parts should always be cut with a little stock and measured and then "sneak" up on the finished size very carefully and slowly with repeated measuring.
    www.integratedmechanical.ca
    Jun 2003
    1365
    I would say that .001 is definately too much runout, I have not measured my own personal runout on my machine, something I should do sometime. But I think it should be well under that.
    Jon
    Apr 2003
    1873
    I wouldn't call .100 run-out I would call it bent
    If you must use that cutter you can rotate the cutter in the collet 90 degrees at a time and re-check the runout in an attempt to average out the error.
    Dec 2004
    86
    So I've had a few different responses but no one seems to agree on just what a hundredth is. A hundredth is what I said, and hopefully a hundredth is still .01", but maybe thats changed since the last time i checked? I didnt get the memo or am I incorrect here?
    Apr 2003
    1873
    My bad, one of those hurry up and read/post issues, well there you go, you can always say you were right at least once
    Are you sure the runout isn't from the collet?
    Dec 2004
    86
    The runout of the collet measured at the collet is ~.0005 or less.
    So since there is this wobble/runout in the collet the further away from the collet the more the perceived runout of the endmill will be. But how can this be calculated? My assumption is that the wobble in the collet that causes the runout must have a point of intersection with the virtual line that represents the perfect spindle axis, no runout. The position of this virtual point of intersection could be used to calculate the angle difference between the ideal and actual runouts. This angle could be used to determine expected runout at any distance from the collet for a perfectly straight endmill. However this is a terribly theoretical approach and not particularly useful in real life as far as I can see. So does anyone have a better/easier way to figure it out?
    Addendum, its possible that the virtual point discussed above can be either infront of (between the collet and table) or behind (in the spindle) and determining that might be a good start.
    Second Addendum, upon re-reading I might be full of it. let me know.
    Apr 2003
    1873
    There may be two possibilities here,
    1) If the collet or spindle or both are canted then I would think the amount is relative to distance down, that is if you measure 1" down from collet and the runout is say .010 (1 hundredth of an inch ) if you go two inches the mount is simply doubled, 3" tripled etc,
    2)if it is not canted and the spindle is simply running out of concentric then it seems this runout will not change with length.
    Aug 2004
    244
    Check the runout with a gage pin in the collet and you know were the runout is coming from.
    Everything in moderation, including moderation.
    4826
    If you have a V-block, and a dial indicator, you can roll the shank of the endmill in the V, while you indicate the highest spots on the flutes. This will tell you if the grind is eccentric relative to the shank.
    More than likely, it might be the state of your chuck or spindle taper that needs checking over.
    Jan 2004
    3154
    Hu and Ken have covered all the angles in this post.
    15
    Who care you got them next to nothing exept you spend a lot of time and come out with nothing, hey now you can throw them away and it will still cost you nothing. :cheers:
    Dec 2004
    86
    Well as bad as the runout is or isnt, I've managed to use them fairly successfully for a few pieces so far and I cant really complain. Even though they may have a slight wobble, that i cant detect in operation or in the finish quality. They run like the dickens, 4 flute carbide yumminess.
  1. 3 Flute High Helix Endmill Problem
    By Joe_CNC in forum MetalWork Discussion
    Last Post: 07-20-2005, 01:07 AM
  2. When to use slotdrill or endmill.
    By MrBean in forum MetalWork Discussion
    Last Post: 03-21-2005, 06:16 AM
  3. Tool changing with endmill holders
    By febisfebi in forum Uncategorised MetalWorking Machines
    Last Post: 08-13-2004, 06:33 AM
  4. 3/8 Ball Endmill in Tool Steel
    By Freddy in forum Hard / High Speed Machining
    Last Post: 09-08-2003, 09:13 PM
  5. Runout
    By grantmi1 in forum Hard / High Speed Machining
    Last Post: 06-12-2003, 09:22 PM
