Hi I'm pretty new to the servo side of CNC, however, I have built at least two working CNC using steppers and linuxCNC.
I need some help to actually size up SERVO + DRIVERS + CONTROLLERS or as a KIT if anyone knows any?
any help will be greatly appreciated, the current machine built is as follows:
its a 5-axis machine, with the 4th & 5th (2-axis spindle head) using timing gear of 20 teeth and a 4" (100mm) slew bearing with ext. gear.
each of the 4th and 5th axis, being driven by a NEMA 24 stepper with uStep @ 10 to give higher precision at rotations, but also finer resolution and OK torque. the 4th and 5th axis can be directly driven by the NEMA 24 stepper, if space is a concern.
the Y-axis uses 2 servo, one on each side.
Its a Gantry system, where the top moves, and the top weights in a max at 125kg (full aluminium extrusion + Hiwin linear rails + PMI ball screw + servos).
so each servo on the Y-axis needs to move say around 70kg ~ 80kg max of weight.
the X-axis uses 1 servo.
It moves the aluminium Z-frame, the spindle, and the 4th and 5th axis head along, weighing in about 70kg max (full aluminium extrusion + Hiwin Linear Rails + PMI ball screw + servo + 4th & 5th head + Spindle)
the Z-axis uses 1 servo.
it moves up & down, carrying with it a max weight of 50kg (full aluminium extrusion + 4th & 5th axis + spindle)
Friction coefficion based on PMI manual is 0>0.005>1.
Lead & Pitch = 10mm since its single start ball screw (otherwise pitch = lead x number of starts)
All axes run on Hiwin Linear Rails which says will reduce weight by 40% if lubricated regularly (once a month) within 2~4 years (100kg will require 60kg of force pushing)
Machine travel speed unloaded (not-cutting) for all axes should be around 40,000mm/min or 4,000rpm (using velocity/lead)
Cutting speed should be around 25,000mm/min ~ 30,000mm/min (2,500rpm ~ 3,000rpm).
Servo should be capable of achieving these speed and cost effective.
I know there are thrust to be calculated, but this is where I get lost...
lots of servo out there and manufacturers with sizing software, and all returns different results...
really need some help here, if anyone can offer any help ?
need the servo size vs price, reliability, what I can really use?
need amplifers or drives or control board? someone told me about some other board? totally confused...
i thought SERVO is just the motor (with encoders), a driver + controller then connect to the computer?
pretty much like a stepper system? or am I wrong about it?
did some search online, but points to nothing much...
looking for any help available
thanks !
