587,997 active members*
1,784 visitors online*
    Machine Lines when V-Carving
    Was wondering if anyone has any tips or trick to get rid rid of or lessen machine lines
    when v-carving. I was using a brand new bit and router. Also, I measured the y axis and it is in sync. I tried getting the router perfectly 90deg to the spoil board by using a bent steel rod. I put the bent steel rod in the router chuck and measured the distance with feeler gauges while rotating it. It helped make the cut a lot cleaner but the lines are still there. I am getting a more accurate gauge to get it closer to 90 but was wondering if anyone had a similar problem and how they fixed it. I am cutting into white pine and my cut depth was .0625 each pass.
    Mar 2008
    1762
    Re: Machine Lines when V-Carving
    It looks like the degree parameter for your VBit is not matching the actual degrees of the bit. Adjust accordingly. If you are a Vectric user there is a method posted in the VCarve Tips and Tricks to rectify this.
    Gary Campbell CNC Technology & Training
    GCnC411 (at) gmail.com www.youtube.com/user/Islaww1/videos
    Quote Originally Posted by islaww View Post
    Ok, thanks that sounds simple enough. I know how to change the angle in vectric but how would I figure out the exact angle on the bit? I did searched through the tips and tricks threads but I didn't see any info on doing this.
  1. the cnc machine is carving above the object.
    By todatop in forum Commercial CNC Wood Routers
    Last Post: 04-30-2014, 04:19 PM
  2. Replies: 1
    Last Post: 08-11-2010, 01:59 PM
