587,223 active members*
3,070 visitors online*
Results 1 to 13 of 13
    Oct 2007
    62
    Design: overhead gantry
    Looking at some large overhead gantry systems, got some questions that maybe you guys can answer. I'm refering to the large picture posted below.
    1. legs: some even larger machines use what looks like concrete legs (along the Y axis on the pic). I understand that steel legs can be moved later on, but wont concrete creep a bit over time, affecting accuraty? It would be quite easier to build with concrete...
    2. speaking of axis: is there a standard for axis? most machines I have seen from DMS (see http://www.5axiscncrouter.com) got the gantry moving along the Y (and it seems like the Y is always longer). Must be easier to have a shorter gantry right?
    3. Rack and pinion: Since you CAN'T have for exemple a ballscrew in the middle of an axis, how to do slave accuratly to make sure both racks and pinions of the same axis always move in tandem?
    4. Z Column: here, the YZ axis plate has the rails for the Z axis (while the blocks could be bolted to the plate and rails to the Z axis). I understand that this allows you to have a counterweight for the Z. But, that adds lot of weight. counterweight or not?
    5. Motors with rack and pinion: looks like the motors on the Y axis are direct drive. Is it possible?
    6. ballscrew over X: is it me or it looks like their is a 10+' ballscrew over the gantry? would accuraty and backslash suffer a lot to go with belt or chain?
    thanks again guys
    24223
    The coordinate configuration appears to be the same as it would be on a standard Mill.
    The Y axis motors may have planetary gear boxes on them, and controllers of this type use electronic gearing, i.e. One motor is master and the other is slaved/geared off the master encoder.
    Al.
    Albert E.
    Oct 2007
    62
    The coordinate configuration appears to be the same as it would be on a Gantry Mill.
    for exemple on a 4X8 table, the gantry is going to be on the 4 foot axis, not the 8 axis unlike those guys. But it can be a good thing with a moving table...
    Al.
    oh yeah, maybe that the blue and silver thing just below the motor....
    Oct 2007
    62
    found the answer to all my questions, thanks anyway
    Sep 2006
    607
    Well I'm a bit curious as to what all the other answers were. Could you please share them with us?
    Oct 2007
    62
    Quote Originally Posted by The Blight View Post
    only because you are danish...
    -They do not use concrete. They use steel tubing that is filled with what looks like a mix of epoxy and fiberglass matting. This helps to dampen vibrations.
    -2 types of gantry: short and long bridge. On a long bridge access is easier to the work piece(s). Also, if you use a moving table, you can move the shorter axis (smaller footprint). check http://www.f-zimmermann.com/ lot of awesome **** on there
    -must be a way to slave correctly 2 engines. Still, it is possible (in my case), to use 2 belts or chain hanging above linked by a steel shaft for synchro.
    if you check http://www.f-zimmermann.com/ again, you see that the heavy machines use a counterweight while the lighter dont. Still havnt checked yet, but I assume std engines are strong enough for a lighter Z.
    -havnt really checked std motors. Maybe their is a planetary gear. Or maybe gearing is just right for weight and speed... not really an engineering problem.
    -Maybe it is the nut that is turning. on a short bridge (5-6', it would be possible to use a ballscrew, or even easier, a chain)
    Mar 2006
    2712
    Ref: counterbalance. Pneumatic counterbalance with cylinders and reservoirs don't weigh all that much. Just a thought.
    Dick Z
    DZASTR
    Oct 2007
    62
    Quote Originally Posted by RICHARD ZASTROW View Post
    Dick Z
    hummmmmmmm....................
    the force is strong with this one
    Sep 2006
    607
    "only because you are danish..."
    Haha! That one made me laugh! And to be honest, I'm Norwegian, but I moved to Denmark a couple years ago.
    Thanks for your answers, and I think I fell in love with this (FZ 37-5 M3ABC) machine. 8000mm long table. Thats a bit of inspiration for my next project. Will be making it of concrete like this swedish guy did (http://www.elektronikforumet.com/for...er=asc&start=0)
    Cheers!
    Oct 2007
    62
    Cheers!
    oh thats fine, norwegian chicks are even better. Those danish girls are dangerous. Once in New-Zealand, 2 tall blond danish chicks tried to sexor me. What s frightening is that they were both taller than me... and I'm 6'3....
    btw, that FZ 37 doesnt have any table, thats a gantry portal (while the swedish guys concrete table is a fixed gantry). I'm personnaly designing something that looks like that FZ 15 with 10x5x4' work area (plus space for 5 axis head)
    I also tough alot about using concrete but I really dont think its going to be stable enough on the long term.
    24223
    Quote Originally Posted by Gizmot View Post
    There are some manuf here (Cincinnati )that install their machines on a concrete base for stability, I wouldn't swear to it, but I believe it is similar to Ferro-Cement, the stuff they make the boats out of.
    Al.
    Albert E.
    Oct 2007
    62
    Al.
    well, there is a couple of patents about concrete machine tools.... and I would love to do it!
    but on the other side. People such as prof Slocum are against using concrete
    While I love the idea of epoxy/granite, i dont think it is cost effective for large machines. Need to look a bit more into it
    Oct 2007
    62
    anyobdy got experience with Fiber reinforced concrete (FRC)?
  1. GANTRY Design
    By bert5604 in forum Waterjet General Topics
    Last Post: 10-01-2007, 02:30 PM
  2. Onsrud Overhead Router
    By marksnwv in forum Open Source CNC Machine Designs
    Last Post: 11-18-2006, 06:18 PM
  3. 1st Machine, Steel ,Overhead Gantry
    By bradodarb in forum CNC Wood Router Project Log
    Last Post: 10-18-2006, 08:05 AM
  4. Gantry design question
    By anthony in forum Mechanical Calculations/Engineering Design
    Last Post: 04-27-2005, 07:39 PM
  5. Gantry design???
    By dmgdesigns in forum DIY CNC Router Table Machines
    Last Post: 05-25-2004, 03:13 PM
