![Quote](images/misc/quote_icon.png)
Originally Posted by
adroitguy
Hello ,
I need some advice from the pros.
I have a bi-polar stepper which is rated for 12V / 0.67A/phase.
This motor is supposed to deliver 7Kgf.cm (97.21 oz.in).
I am driving this with a L297/L298 combination .
I attached a weight to the pulley and tried lifting a dead weight and found a maximum pulling torque of 4kg.cm @ 60rpm. I am inable to go beyond that with this.
I am using a 24VAC transformer with a bridge and a 2200uF cap to filter the AC.
Is this a valid design ?Where am I going wrong ? I need 7kg.cm atleast upto 120RPM .
Can anyone help me ?
I will supply any additional info as required .
Regards
12 volts dc?
hummm
no good for 297 298 drivers!
these motors are high resistance phase ! + - 10 ohm ?!
I recommend you to measure the resistance of 1 phase, and itself is taller than 3 ohms, that motor are not all right for the pilotage in pwm 297 298 .
you will also have always a low couple feeding them to 40 volts.
visit my site!!
hi
my steppers turn to 17000 step/s, my stepper drivers arrive to more than 50000 step/ses :- (
