588,411 active members*
5,417 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Silicon Sealant work with coolant??
Results 1 to 6 of 6
    Oct 2005
    612
    About to build my enclosure for my X3 mill and need to know if silicon sealant is suitable to run in some of the joints. Will it be OK with coolant splashing about?
    cheers,
    Rod
    Perth, Western Australia
    Jul 2005
    12177
    Yes, use bathtub/shower enclosure sealant. It contains a fungicide to prevent mildew.
    Oct 2005
    612
    Thanks Geof
    cheers,
    Rod
    Dec 2006
    242
    I would use true 100% RTV Silicone like General Electric. There are some bathroom sealants that are not silicone and do not stay flexible. RTV won't break down with any normal coolant. Keep the coolant skimmed and no problem.
    Mar 2005
    1673
    Hi Rod,
    I haven’t had much luck with general purpose silicon but had the need to use aquarium repair silicon a while back. This stuff sticks like sh*t to a blanket and I have never had a joint leak. May be the same stuff as mentioned above.
    John
    Oct 2005
    612
    I had a feeling there might be more to this than simply grabbing the first open tube of sealant and squirting away. I wouldn't want my blanket coming unstuck so aquarium/RTV it is and thanks for the advice.
    cheers,
    Rod
  1. Coolant or No Coolant when turning....
    By Crashmaster in forum MetalWork Discussion
    Last Post: 05-20-2007, 07:20 AM
  2. Silicon Nitride Milling Inserts?
    By ajl6549 in forum MetalWork Discussion
    Last Post: 02-12-2007, 03:23 PM
  3. Machinist looking for work in Silicon Valley
    By Grinding Guy in forum Employment Opportunity
    Last Post: 10-30-2006, 12:07 AM
  4. Silicon Bronze
    By drakesis in forum Casting Metals
    Last Post: 02-24-2006, 12:18 AM
  5. Does Enco brand coolant work alright?
    By phantomcow2 in forum MetalWork Discussion
    Last Post: 12-03-2005, 01:41 AM
