586,915 active members*
2,935 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    6855
    Show us your steam engine
    Let's see pictures of your own steam engines.
    Cannon_Man Guest
    Steam Wobbler
    Heres a pic of a simple steam wobbler I made from a casting kit a while back.
    Oct 2003
    92
    Nice work!
    --bb99
    There are 10 types of people in this world; those that understand binary and those that don't.
    Dec 2004
    Hello
    Here is some pictures of my first steam engine. I made it a couple of years ago.
    \Jonas
    http://www.geocities.com/jcee324
    May 2005
    89
    Here's a Vertical 'Upside Down' Engine that I made a couple of years back. No Castings were hurt in the production of this model - everything was made from solid material - no Castings, no CNC, no Mill - just a Lathe, a Drill Press and a lot of hand & File work. I was quite pleased how it turned out, as it was my first Steam Engine.
    Skype me on imagineeringnz
    Intuitor: (noun)
    A person with a passion for learning and innovating that is so strong it is often more powerful than the desire to eat, sleep or seek personal wealth.
    Ummm . . . Guilty as charged.
    Apr 2004
    105
    Picture of my fathers 7 1/4" 'H' class 3 cylinder loco. This shot was some time ago, its now nearing completion after 10 years of work.
    Feb 2006
    175
    deleted post
    Sorry , I could not post the picture
    1880
    if you posted a picture or link it didn't show up.
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
    Feb 2006
    175
    Well I don't understand it.
    I hit the browse, and selected a picture.
    Waited while it downloaded, and when it was complete, I hit submit.
    Never showede up. I did an "edit" and repeated, and it's a no show.
    Sorry
    Rich
    1880
    when you upload your picture be sure to read the addition text in the upload section.
    This was the mistake I made. It will usually tell you why it didn't upload.
    if that dosn't help I am out of suggestions
    thanks
    Michael T.
    Oct 2003
    175
    i haven't got into it yet but the guy that helped me and taught me alot of machining when i built my cnc has built alot he does some really cool work ...... heres a few pics of some of his stuff
    746
    Mine is packed away but it is an original Creators steam engine that powered the popcorn wagon. At one time someone offered me a $1000 for it but I said no because I had no idea what it is really worth.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    Feb 2006
    77
    I want to see a model steam turbine, anyone built one?
    Feb 2006
    175
    Well i tried to upload again, and I got an error message
    that said "invalid file type.
    The picture is a jpg.
    Rich
    I will try to take a fresh picture of it and send again.
    Could it be that I shrunk it down to 38K for posting ?
    Jun 2005
    95
    100% CNC Machined - Enjoy
    Attached, please find images of a P.M. Research re-make, which is 100% CNC machined. With the exception of fasteners, of course.
    Attached Files Attached Files
    May 2006
    138
    Nicely designed oscillating engine deanrach. Think it's only do-able on CNC that one!
    One question, how do you get the seal between the cylinder and port faces? Usually there's a spring to keep them pressed against each other ..
    Nick
    Jun 2005
    95
    Nick,
    I had my students reproduce (with permission) the kit version as offered by P.M. Research - see the attached link.
    http://www.pmresearchinc.com/store/c...2&cat=4&page=1
    If you look at post #1, you'll see it's the same steam engine. The only difference being that my students machined every part from solid stock, no castings and 100% CNC machined.
    As for the spring, we used a spring washer - I can get you the part number we used through McMaster Carr.
    May 2006
    138
    Thanks for that. It looks much better machined from the solid than from those castings!
    Good idea using a spring washer. I have often thought of doing that as there is no need for a long spring, you don't need to vary the spring pressure, just keep it enough to make a good seal.
    Nick
    May 2006
    138
    Here are some pictures of an Oscillating steam engine or wobbler I made when I was 15 for my GCSE Technology project.
    The engine was all made from stock and was my own design. I was very proud at the time, but when I look back on it now, the finish on some of the components wasn't great.
    Having said that, it ran brilliantly, partly due to the relatively large bore and stroke and heavy steel flywheel I think. You could just turn it over on lung power.
    I sold the engine on ebay, partly because I thought it may fetch more than 20 pounds! But mainly because it was just sat in a box at home and it someone else could give it a better home! I can easily make a better one now if I want.
    Nick
    Jul 2004
    100
    Live Steam Turbine
    Quote Originally Posted by Beaker View Post
    One of the magazines, Popular Science, Mechanix Illustrated etc. had plans for a live steam model of the USS Savanna back in the '60's. Please let me know if you find a copy!
    Regards, Ray in FLA
    ​"There is no such thing as a gun free zone."
    Ray Brandes, Ray-Vin.Com, PCB, FL 32408 USA
Page 1 of 2 12
  1. The Most Powerful Diesel Engine in the World!
    By WallCrawler in forum Community Club House
    Last Post: 07-25-2010, 07:50 PM
