587,218 active members*
2,661 visitors online*
IndustryArena Forum > Material Technology > Glass, Plastic and Stone > Machining colered translucent display covers and light pipes
    Hi guys/gals,I am wondering what type of material to use to make 2 different things1) Translucent colored display covers like you would see on a stereo. In my case, 6 digit 7 segment displays. (see pic)(2) Light pipes. This is the plastic you see inside various electronics that are in all sorts of strange shapes. When an LED injects light into one end, it pipes through the plastic and you see the light on the other side with very little loss. With todays surface mount technology these things are a must. I want to make my own but I know the plastic is not just any plastic.
    I have found some information, so I thought I would share for anyone else who may find my post:
    Most of the light pipes are made from a clear acrylic or polycarbonate "optical grade" plastic. I have ordered some cast acrylic and polycarbonate so I will report my results.
    I have found a link to a good pdf detailing light pipe design:
    http://www.ciri.org.nz/downloads/Lightpipe%20design.pdf
    I need to find a way to diffuse the end of my lightpipe. Maybe the cutting can do it itself, I dont know yet.
    Colin
    Dec 2004
    1137
    Colin, I found that just sanding either the LED or the far end of the pipe will diffuse it. I have also used glue stick glue
    Jay
    Thanks! I like the glue stick glue idea, I bet that will work well in this situation. I can simply fill the holes with hot glue.
    Dec 2004
    1137
    I've seen some small glue sticks out there maybe 1/4" ... might make a bendable light pipe might not
    jay
  1. Replies: 6
    Last Post: 10-26-2008, 12:16 AM
  2. Maztrol M32 - No monitor display No drive light
    By nbodie in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-17-2008, 08:26 PM
  3. Spectra light and Light machine owners have ?
    By ZipSnipe in forum Benchtop Machines
    Last Post: 07-19-2008, 03:52 AM
  4. How to cut PEX-AL-PEX pipes
    By DavoH in forum Glass, Plastic and Stone
    Last Post: 11-30-2007, 10:46 AM
  5. Machine Recommendations Please - Light Duty, Prototyping, Light Production in metal
    By SCG11762 in forum Uncategorised MetalWorking Machines
    Last Post: 08-27-2007, 02:08 PM
