588,055 active members*
4,475 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Recommendation of a suitable software for my Biesse Rover C6
Results 1 to 13 of 13
    Smile Recommendation of a suitable software for my Biesse Rover C6
    Hello....
    I'm looking for a simple software and post processor for the Rover C6 any recommendations??? http://www.cnczone.com/forums/images/icons/icon7.png
    Apr 2004
    5755
    Re: Recommendation of a suitable software for my Biesse Rover C6
    If you get any version of VisualMill, Mecsoft will configure a post-processor for free, if your machine isn't already on the list of posts https://mecsoft.com/downloadposts/ (I'm not seeing one for the Rover). All you need to supply is a sample of G-code that works on your machine; they'll do the rest. And if you want a discount on the software, let me know.
    Andrew Werby
    Website
    Apr 2009
    5516
    I'd check out one of the cabinetmaking or woodworking CAM products... IIRC Biesse has some crazy g-code language...
    Thank you guys let me check out the Visualmill software and see if its a good fit for the machine.
    Your help is much appreciated.
    What are you using the machine for? That has a lot to do with what software you use.
    Sep 2011
    41
    Quote Originally Posted by andrewshuma View Post
    Hello....
    What problems do you have with the original software supplied with the machine?
    Apr 2009
    5516
    TopSolid... I know one shop nearby that uses it...
    I do a lot of work with a shop that uses TopSolid. They have a couple seats, and about $40K into it.
    Hey,
    its a 5 axis machine and its quite difficult for me to program 3D drawings and angle cuts.
    For now i'm using it to cut some complex cuts for ridge beams and trusses.But in general i'll be doing windows and doors.
    I'm looking for a simple software ...........................
    ........................... its a 5 axis machine
    There's no such thing as "simple" 5 axis software.
    My suggestion would be MasterCAM Router or AlphaCAM Router.
    The software that came with the machine is biesseworks.
    Its quite tricky to do 3D drawings in biesseworks.
    Sep 2011
    41
    Hi, Have you talked to BiesseUK about the software?
    They could help, even upgrade your machine to the newer bSolid software now being shipped with their machines.
    May 2015
    60
    Alphacam and Biesse are very very nice pair,,,
    mastercam is iffy
  1. Biesse Rover 22, CAM software
    By lolaalol in forum Uncategorised CAM Discussion
    Last Post: 07-16-2023, 10:53 PM
  2. IMPORTANT! :( Software for Biesse Rover 22
    By astojkovski in forum Uncategorised CAM Discussion
    Last Post: 01-02-2023, 02:41 PM
  3. software NC 500 for rover biesse
    By Arias in forum Uncategorised CAM Discussion
    Last Post: 05-14-2019, 02:10 AM
  4. BIESSE ROVER 336 XNC 1.2 SOFTWARE
    By EsterSpS in forum CNC Machining Centers
    Last Post: 04-25-2017, 12:12 AM
  5. Need Biesse Rover 316 software
    By mar404 in forum Biesse
    Last Post: 08-03-2011, 01:50 PM
