Originally Posted by
Nicky Melitech
Hi All,
Can anyone guide me to what I'm doing wrong please?
I have an Okuma OSP5020L controller and after I run this simple program I always get error saying (452 Alarm-B Data word circle cal 3). The program is the following:
N10 G00 Z550
N20 T0707
N30 G50 S1100 S100 M04
N100 G00 X0 Z200
N110 G02 X5 Z205 I0 K205 (I also tried using G90 and G91 with this line)
N400 M05 M30
This is really far off, You are starting your tool 200 MM away from zero? Ok maybe your zero is behind the face of your part. You are still only moving on the Z axis 5 MM and on the X axis 5 MM ?? Concave radius, or convex going towards the front of the part?
Like OW said lose the IK commands and stick with L values but the L value needs to be half of the X value, if you want a full radius.
The sample posted would be a lot easier to interpret if the face of the part were zero and you were moving toward the chuck in minus increment. The G90/G91 will just complicate things. If I am understanding correctly this is very simple, just not so much.
Robert
The beaten path, is exclusively for beaten men.
