588,687 active members*
6,223 visitors online*
    Jan 2017
    10
    HELP REQUIRED REGARDING STEPPER MOTORS
    HI GUYS .... I HAVE A 4 WIRE STEPPER MOTOR AND IM JUST TRYING TO IDENTIFY WIRING .... ie A+ A- B+ B- THE COLOURS ARE RED\WHITE\BLUE\YELLOW...... WITH MY CONTINUITY TESTER I KNOW RED/BLUE ARE PAIRED AND WHITE/YELLOW ARE PAIRED ... CAN ANYONE TELL ME HOW TO TELL WHICH IS + AND WHICH IS - ...THANKS IN ADVANCE
    Jun 2008
    128
    Re: HELP REQUIRED REGARDING STEPPER MOTORS
    It does not matter which is + or -
    Just hook up one pair to A+/- and one pair to B+/-
    If rotation direction is wrong you can either change direction in software or change one pair of wires
    FYI stepper drivers have 4 states so direction of wire hookup does not matter
    -> A+ to A- ,B+ to B-
    -> A+ to A- ,B- to +
    -> A- to A+ ,B+ to B-
    -> A- to A+ ,B- to B+ then 4 steps repeate
    Microstepping is done by change in current level in A and B
    Jan 2017
    10
    thanks very much for your reply george .....im upgrading my chinese cutter which doesnt have stepper drivers fitted...the motors were wired straight into the control board .... im upgrading to a awc708c controller and the wiring diagram shows it connected to drivers before motors so ive got a pair ordered
  1. Is shielded cable required for stepper motors?
    By will_eng in forum CNC Machine Related Electronics
    Last Post: 04-21-2012, 02:13 AM
  2. Required Stepper Torque for acceleration
    By CNC43711 in forum Mechanical Calculations/Engineering Design
    Last Post: 08-16-2010, 03:18 PM
  3. Stepper motors or servo required?
    By vwdevotee in forum Stepper Motors / Drives
    Last Post: 06-21-2010, 09:39 PM
  4. Replies: 2
    Last Post: 07-12-2009, 10:10 AM
  5. stepper size required
    By bru in forum Stepper Motors / Drives
    Last Post: 12-24-2006, 09:38 PM
