Hi
sorry my bad
I use the old and new Ubuntu Live Cd for testing.
So it is an 8.x Ubuntu with come 2.3x version of EMC2 which i use for my Proxxon F70 (usovo ) cnc mill.
My Turning lathe should run on the new Ubuntu 10.x Emc2 2.4.5 which i use from now on. So the old config was only to see if i have some unix issue but it wasnt.
So i did use stepconfig for config straight forward.
The idea was to emulate an standard Mach3 mill config.
Which is described straight forward in the documentation (
http://www.sorotec.de/jo15/index.php...ownload&cid=32) of the controller.
I do use dual boot so i did then an mach3 install and it worked. So,...
Then i tried to do an no chargepump install. So i set the jumpers according the docu and reconfigured the pins. and then i did an chargepump no pmw config but all 3 did not work so my question is where can i find hints how to track down log the issue or see why it did not work.
thank you for the fast reply
best reg thomas
