588,568 active members*
4,801 visitors online*
    Jan 2008
    35
    Helical Bore Milling
    I have to produce a series of dia' 70mm (proper measurements!! haha!) bores in P20.
    They are 81mm deep, blind, flat bottom.
    I dont really want to have multiple operations, but was thinking 20mm drill to depth, then dia' 40mm inserted facemill to helical mill.
    (or ideally, mill from solid)
    My question is, what is the best insert shape for this?
    I've got to buy a new holder anyway.
    probably go for a shell mill fixation, with a long series holder to suit.
    I have 15k rpm.
    high pressure TSC
    very rigid fixture.
    5-axis Mikron HPM1150
    HSK63-A 'backends'
    Any suggestions gratefully received.
    May 2004
    82
    Make sure that the tool can ramp . Very few facemills can. Helical milling works very well IMO a round insert is god because the edges are strong. GET RID OF THE CHIPS or they'll ruin your tool.
    Bent
  1. Helical Bore Milling Tooling
    By Ginger_Ninja54 in forum CNC Tooling
    Last Post: 01-19-2008, 04:15 PM
  2. Helical Milling
    By binzer in forum GibbsCAM
    Last Post: 03-30-2007, 10:39 PM
  3. GN6 (General Numeric) Helical milling
    By pauldkeeton in forum Fanuc
    Last Post: 02-23-2007, 10:42 PM
  4. Helical milling with HAAS
    By dinger in forum G-Code Programing
    Last Post: 06-19-2006, 07:36 AM
  5. helical milling
    By hogman in forum GibbsCAM
    Last Post: 04-22-2006, 02:15 AM
