587,167 active members*
3,644 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang 2.2kW water cooled spindle with VFD won't work
Results 1 to 1 of 1
    Dec 2020
    Hey all. Just bought the 2.2kW 80mm spindle with VFD. I already experimented with the 65mm 800W spindle with VFD before and it worked ok. this one doesn't. So I wired everything presumably correct. It would only work on super low RPM and if I increase RPM it would stop with an error on VFD.
    See screenshots of my wiring attached. I have 14 gauge 4way cable: white wire on 1 and U, black on 2 and V, red on 3 and W, yellow is earth. And 14gauge power cable 110V.
    My settings are the one they provide in their YouTube video:
    P013 = 8
    P005 = 400
    P004 = 400
    P002 = 1
    P072 = 400
    P144 = 3000
    Attached Thumbnails Attached Thumbnails Photo 28.01.2024, 10 46 09.jpg   Photo 28.01.2024, 10 46 16.jpg   Photo 28.01.2024, 10 46 05.jpg
    Mar 2024
    Re: Huanyang 2.2kW water cooled spindle with VFD won't work
    Did you find a solution to this? I have the same problem. Is the VFD bad?
